how to tell if my old heads ar patriot performance heads?
Old 01-11-2008, 08:01 PM
Disturbed Bird's Avatar
Default how to tell if my old heads ar patriot performance heads?
i took off my old ls6 heads and they look exactly like my new stage 2 heads except that my new heads have gold springs is there something that PP marks on there heads to tell its theres?
Old 01-11-2008, 08:17 PM
THE CHOP SHOP's Avatar
They do stamp a serial number on the head. It would be on the side of it that is machined flat and some of the other head manufacturer's will engrave their name on.
Old 01-11-2008, 08:22 PM
there is a number on the exhaust port side if thats it?
Old 01-11-2008, 08:27 PM
it is pretty small on my heads. I thought it was a GM number then I realized it was more like stamped in. They may have put them in different locations. I bey you will be a little pissed if they are the same heads. If they are an older set I think they redesigned the porting so you could still make more power with the new heads.
Old 01-11-2008, 08:38 PM
ya just a little but at least it will be new. and i can sell them for a little more. if they are what do you think they are worth?
Old 01-12-2008, 03:48 PM
itslow's Avatar
Look for a 4 digit number stamped into the end of the head on the face upon which the accessory brackets bolt. Small numbers, ~1/8" tall.
Old 01-12-2008, 04:23 PM
ya i found it last night thanks anywas.
Old 06-05-2010, 08:48 AM
OLDSCHOOL85's Avatar
Default Stamped Serial Number
Where is the stamped serial number on the Patriot head?
