BFG Drag Radial INFLATION
I have a set of the BFG drag radial t/a's.... about what pressure should i be running these at? and what is an average rpm to launch at for a pretty much stock a4 with a 373 rear?
I run mine at 12 psi @ the track. I have a 4k stall and flash it and as long as there is a half decent prep I see fairly good 60', can't wait till I get a day thats warm enough for them to run full 1/4 instead of 1/8th.
Oddly enough, I've run my BFG DRs at 30 psi and have yet to break them loose while dumping the clutch at 4500. Admittedly, the slipping clutch is taking some of the shock away from the tires. But, I always like to start with the air pressure high, then work my way down to the highest pressure that will consistently hook. The car transitions nicely from the 60'-330' mark and feels a lot better in the traps with a little more pressure.
LS1Tech Sponsor
i ran mine at 20 ish at the track last year with very good results! 275/35/18 FWIW
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
