Who would you call to touch up some cylinder heads...
Re: Who would you call to touch up some cylinder heads...
depends on the money you want to spend. GTP will get you the top of the line cyllinder heads w/ a flow sheet. if you just need a "cleanup" job as in a valvejob, guides, seals, new valves, and some minor port work, you can either take the time and learn it yourself, or look for somone that is comfortable making these kinds of changes w/ the help of a good machine shop.
6600 rpm clutch dump of death Administrator
One of the things I will say about GTP is that they have played around with their vavle jobs to find which agles make better flow. If anyone doesn't believe that matters, look at a GTP flowsheet. One of the secrets is the valve job. A god valave job can mean 20cfm. Whoever you decide to go with make sure they can do some nice seats instead of some production shop" crummy job with wide angles and poor flow.
Send them to Richard at West Coast Cylinder Heads... West Coast Cylinder Heads
We have touched up a variety of heads out there including Fireballs with excellent results.
Joe.
Joe.
FOr the money, nothing beats a Patriot head. They flow as good as TEA heads for a lot less. they cost $1295 from Texas Speed and Performance and they don't require a core. HEck, they will even buy your old heads for $200. TEA's ar $1700 + the core. If you got the dough go with GTP or ARE heads. They are the best. They use smaller cylinder ports and flow more at a higher speed which helps with throttle reponse and torque.
