SBC combo???
SBC combo???
So I am putting together another 350 for my 78' Regal. Tell me what you guys think of this combo.....
350, .030 over 4 bolt block
Performer RPM heads 64cc
KB 10.2:1 forged pistons
RPM intake.
625cfm Demon carb
244/252, .518/.536 112 lobe with a 107 intake centerline (mechanical flat tappet)
TH-350, 3200 stall, 2.2 STR
3.90 gear, full length headers, mandrel bent duals.
weights 3290lbs
let me know what you guys think, any input helps
Justin
RPM intake.
625cfm Demon carb
weights 3290lbs
Justin
You might want to use a different set of heads, here are a couple of suggestions:
http://cgi.ebay.com/ebaymotors/AFR-1...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Dart-...QQcmdZViewItem
http://www.patriot-performance.com/w...05238&DID=1225
I would also move the LSA of the cam closer to optimum, which will be around 108*. For your vaccum brakes a 110 LSA will probably be as far as you would want to venture. Then depending on which set of heads you use, find the best advancement for the ICL.
Well with a regular Fel-pro 1003 head gasket you compression ratio will be approx. 9.77:1. You should be around 446 HP & 473 TQ if everything is ideal according to my Dynomation program. For the money I would deck the block as there are several benefits to doing so. If you get your compression up over 10:1 then I would say that the cam you have would be ok, but if you don't then I would buy a custom grind cam to pull your components together.
Thanks for the info
Justin
ModelAMafia
