Need help with LT1 T56 info
Old 01-12-2008, 09:25 AM
TurboLark's Avatar
Default Need help with LT1 T56 info
I just got a cheap t56, but it didnt come with the clutch fork. It looks like there may also be something missing from around the input shaft against the front plate of the trans(a couple empty bolt holes).
If anyone has a clear picture of what the trans looks like around that area with parts that would be greatly appreciated.
Thanks,
Phil
Old 01-12-2008, 09:48 AM
thesource's Avatar
The clutch fork bolts in on the driver side of the inputshaft .
Old 01-12-2008, 10:32 AM
TurboLark's Avatar
So if i buy a clutch fork, it bolts right to the face of the trans with the 2 bolt holes i see ?
Old 01-12-2008, 01:11 PM
thesource's Avatar
It bolts in with a single bolt .
Old 01-12-2008, 06:04 PM
Jon94Z's Avatar
I can take pics of my T56 and clutch fork, but I don't have the clutch fork bolted on right now.
Old 01-12-2008, 06:25 PM
Jon94Z's Avatar
Ok I found a picture; this isn't mine but you can see the clutch fork on there.
http://ourworld.cs.com/Jon94Z/bellhousing.jpg
Old 01-12-2008, 07:46 PM
thesource's Avatar
Ok ???
Old 01-12-2008, 08:45 PM
TurboLark's Avatar
That is NOT what mine looks like. the bellhousing lines up with my gen1 SBC block in the garage, and bolts to the trans also. Here are some pics of what I have.
Here is a pic of the bellhousing.
Looks like I was sent a LS1 trans huh?
Old 01-13-2008, 10:03 AM
Jon94Z's Avatar
I don't know enough about them to tell you what you have, but I definitely agree it's different. Maybe someone that knows more can tell.
