View Poll Results: Dart Springs or Duals
Stay with the Dart springs.
2
40.00%
Replace with new PRC Duals.
2
40.00%
Replace with my current used PRC duals.
1
20.00%
Voters: 5. You may not vote on this poll
Use stock Dart Valve Springs or go to Duals?
The PSI 1511 valve springs on your Dart heads are superior springs to the PRC's, have better surface treatment and will rev higher. I wouldn't use anything else unless they won't support the lift. Also, the titanium retainers on your Dart setup are only 6 grams. Check out Katech's web site, they tested a ton of springs that they considered for their 427 builds, they selected the springs you are thinking of removing.
Yes they are advertised to be good for .620 lift. I have them on my car and they haven't been on long but no problems so far. My cam is .588/.595 lift.
Does anyone know where to buy a replacement set of these springs? I would like to have a set for when I eventually need to change them but can't seem to find them for sale anywhere.
