Nitrous Oxide - mounting pressure guage?
GT Griller
01-12-2008, 08:01 PM
What all is involved in running the pressure guage like this?
http://i2.photobucket.com/albums/y16/Z28Boy/switchpanel1.jpg
Nick@HSW
01-12-2008, 08:06 PM
Not much at all. I would suggest buying an electrical pressure gague...With that its just running a few electrical wires, hooking up a pressure transducer and mounting the gauge :nod:
jmill96Z
01-12-2008, 08:20 PM
You can run a line off a bottle nut adapter to the gauge. The elcetric gauges are cool, but I guess I'd rather spend money on other things like an interface :cool:
GT Griller
01-12-2008, 08:23 PM
SO if i order one of ur wet kits......instead of getting the bottle mounted one that comes with the kti can i switch out for an electrical one? What would be the extra cost?
jmill96Z
01-12-2008, 08:27 PM
Just remember to put a plug on the port for the bottle mounted gauge if you do that.
GT Griller
01-12-2008, 08:36 PM
U mean run a nitrous line all the way up to the dash?....has anyone done that but to one of those pillar pods?
jmill96Z
01-12-2008, 08:38 PM
I haven't seen any one run a line all the way to the pillar. If you want to put it up there you will have to go electric because the mech gauge is kind of deep. I thought you wanted it on the console, which is why I suggested the mech.
ClemsonStang
01-13-2008, 07:25 PM
elec pressure gauges are 150-150 for an autometer. or your going to need about an 8' peice of an line to go from a spare tire mount to the dash mount.
GT Griller
01-13-2008, 07:45 PM
wow thats pretty expensive
Nitro Dave's Nitrous Outlet
01-13-2008, 11:53 PM
The electric gauges cost a bit more but are well worth it. If you plan on useing a piller pod and gauge Im not sure if there is even room to run a hose up through there for a machanical gauge. If you want to do a switch panle like the one you showed with a gauge you should be fine going electrical or machanical.
Dave
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
