Nitrous Oxide - MSD Window Switch
View Full Version : MSD Window Switch
Z28Caves60
01-12-2008, 08:32 PM
I was wondering is it true for an LS1 that you have to have the MSD window switch set on 4-cylinder mode
jmill96Z
01-12-2008, 08:40 PM
It is true. It took me about an hour to figure out why mine was reading off, then I switched it and it's perfect----we're talking about the digital right?
Z28Caves60
01-12-2008, 09:07 PM
No i got the regular switch it has two loops you can cut for 8cyl 6cyl 4cyl
getthesand0ut
01-12-2008, 09:13 PM
the digital is 4 for sure but i think they both are.
Nitro Dave's Nitrous Outlet
01-14-2008, 12:00 AM
If you have the MSD that takes pills and has not been modified for the LS1 yes you will cut both loop wires.
Dave
jcolews6
03-16-2008, 08:21 PM
I was just searching this exact same thing. I had to alter my shift light the same way. Thanks Nitro Dave. While I have you here I need an adapter for the fuel test port for my fuel pressure guage and 4an nitrous line. Do you have this? Thanks
