Would i gain any By advancing my cam 2*
had a friend bring up this idea to me the other day im just curious as to would it benifit me in any aspect of power wise. The cam is a Torquer V2 112lsa and i instaled it Dot-To-Dot .So what do you guys think is it worth it just looking for alittle more power out of my old car .and if i did would i have to get it retuned or etc.and what degree can i advance it im on stock 806 heads and gaskets.
https://ls1tech.com/forums/generation-iii-internal-engine/841497-i-need-help-i-m-moving-torquer-2-need-advice.html
This was covered the other day, I was thinking of ditching my T2 but was talked into advancing it 4 degrees. And there is no advance ground into it unless you requested it when you bought it.
I once degreed in a cam when I was building an engine. I found the cam
was advanced a little over 3 degrees, so I decided to ADV it 2 degrees. That was a HUGE mistake. The car lost massive top end power and really ran worse on bottom. I had to yank the cover and retard it (adj timing gear) 2 degrees. The engine cam alive on bottom and top end. My advice, DONT DO IT.
