General Maintenance & Repairs - Changing Brake Pad's Question??
Badguy7
01-13-2008, 02:49 PM
Ok, so im painting my brake caliper's right now, and i noticed that im going to need new brake pad's.
So my question is, how difficult is it to change the brake pad's??? Or is it not as difficult as it look's to be.
SpaZMaN
01-13-2008, 02:50 PM
I'd rank it at 3/10 diffuculty...I did a full pad change and painted my calipers in one night, no diffcultly.
sdm1234
01-14-2008, 02:54 PM
it's easy. don't worry. just unbolt the caliper, and slide the pad out.
1 FMF
01-14-2008, 05:06 PM
I'm guessing you're painting the calipers on the car, and not removing the brake lines so you won't have to do any bleeding.
your biggest hangup will be pushing the caliper piston inwards so you have enough space with the new pads to fit on the rotor. Depending on the condition and age of your calipers it might be easy to do by hand or hard with a c-clamp.
I would try, before you do any painting, to push the pistons in fully on all calipers. Be sure to open the master cylinder resevoir cap and you might need to crack the bleeder valve at the caliper. That'll give you an idea if you're calipers are in ok condition, if you can't push the pistons in fully you most likely won't fit the caliper with new pads on the rotor. If that's the case, get some new/reman calipers first and paint those instead- so sense putting work into a bad part. The actual brake pad change is easy, it's fitting a used caliper with new pads over the rotor.
3pnt4maro
01-15-2008, 09:24 PM
definitely use a c clamp and an old pad
chromeplated500
01-15-2008, 09:33 PM
or a block of wood. I love disc brakes... Toom me 2.5 hours to change the back brake shoes on my truck... why do they haveta put 200 springs in the damn thing.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
