Nitrous Oxide - question about purge...
View Full Version : question about purge...
99FormulaM6
01-13-2008, 03:04 PM
I have a ZEX purge kit that came with the car...and shouldnt one end of this be flared? how is this going to stay connected to the solenoid??
http://img.photobucket.com/albums/v321/99formulam6/IMG_3163.jpg
jmill96Z
01-13-2008, 03:59 PM
Most people will ditch that tube and go with a flexible line from a hardware store. There should be a compression fitting on that though. Just a little barrel that goes on the line, under the nut
99FormulaM6
01-13-2008, 04:15 PM
the fitting is there...but even when i tightened it down (hand tight) it didnt seem like it would hold the line..
what size line should i get at the hardware store?
Nick@HSW
01-13-2008, 05:51 PM
Are you using the ferrule? Its a small brass ring that slides on the tube and both ends have a taper sort of forming a spherical-trapazoidal shape. You need that in order to make a compression seal holding the tube in.
Nick
