A poll on Drag Radials
I'd disagree. You'll shock those tires with a 4.30 gear and your launches may be inconsistent. I'd run a hoosier drag radial because of the softer sidewalls they have. That will help with the shock of a hard launch. Just make sure you are ready to do a rearend if you have your stocker still in place (guessing you don't with 4.30s).
A biasply ET street or Hoosier QTP DOT will do even better than these with a 6 speed if you go that route. Just keep in mind that all of these I listed won't last you long on the street nor do well in bad weather.
