oil supply for rear mount turbo's
where is everybody geting their oil supply at? i dont see any oil boss's by the filter. and i dont see any spots on my 6.0L blocks. any help is greatly appreciated. thanks
- Scottie
- Scottie
Right above the oil filter is a piece that has two 9 or 10 mm bolts. Take that off. Look at it closely and you'll see a "boss" where you can drill and tap. The hole is already started but its blind meaning its not all the way through. Drill and tap it and there you go.
Or if you want to do it the easy way, go to the sponsor section and look for a post by turbo tech...they have a piece already to bolt up right here that does the same trick.
J
meh...i'll do it for you...
https://ls1tech.com/forums/sponsor-sales-specials/839182-tti-oil-adapter-plate.html
J
