schaffer
01-14-2008, 08:52 AM
Alright, I did quite a bit of searching and haven't come across any threads about the problem I am having with my factory alarm on my 2002 WS6 - so here is the problem:
Started off with the alarm going off right after I would arm it - did check the shock sensor and no luck - decided to just leave car unarmed and just manually locked the doors with the keys.
Came back to car a couple days later and the battery was drained - charged it up - took it for a drive and came back home and low and behold the alarm works normal again. Again car sat for a couple days and when I started it - it started fine - battery was fine. Then I drove it around the block - came back and the alarm goes off right after I arm it - just like before. Didn't have time to work on car - so I locked with keys again - and as you guess it - when I came back to car yesterday - battery dead. Charged battery and started searching on here - came across the programming the alarm posts.
As I started reading, I read about changing the security system modes and I noticed that I think my alarm is "stuck" in the changing mode - even with radio fuse in and the keys out of the ignition. If I use the unlock button - even with doors closed - it changes the mode of the security system?? Also, the security light stays lite all the time. I also notice if I start car and shut it off and remove keys - the car tones at me twice - indicating it is going into change mode - just like if radio fuse was out (but it isn't and I have confirmed that the radio fuse is functional - if I pull - radio goes dead).
Only other thing I did yesterday was add the additional remote to the system that I had since I was messing with the alarm system.
Sound familar to anyone? Anyone have any ideas?
