PRC 5.3 stage 2.5 users come in. Wondering if this will clear
I have PRC 5.3 stage 2.5 heads with the torquer 2 595/598. I see alot of people running the MS3 (603/609). If I put 1.75 rockers on that would bump my lift to 612/616. Is that to much and does the duration change any? Gonna switch to scorpion roller rockers anyway so I was wondering if I could get any extra out of my cam. The heads havn't been milled. I wanna say there 62cc combustion chambers. Thanks
LS1Tech Premium Sponsor
I haven't tried it with those rockers. Your best bet is to check it just to be sure.
If we build the heads to your specs we can build them to clear that without issues.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Hey jason I called and talked to you guys about it today. I already bought the heads from you guys. I didn't have anything extra done to them. No milling and I have stock replacment GM head gaskets. Whats the biggest cam you guys have seen run with these heads?
