WTB-243 Head
WTB-243 Head
From 2003 Z06 Vette. One of mine was damaged with a broken valve. The other head and block are fine (.020 over on the cylinder). Anyway, I could really use a 243. I'm willing to buy a pair if I have to. TIA......Glenn P
I have a 03 zo6 243 cylinder head. I bought this head roughly 7-10 months ago. At that time the guy i bought the heads from says the heads was redone by a professional shop in Ca. something happened to the engine after 1500 miles on them. It had 3 angle valve job, Dual coil Manley spring capable of lift up to .650,locks,retainers. The only thing wrong with the heads is the titanium retainers nicked up from shipping because the person didn't put the tall enough divider between the heads ( roughly 6 titanum retainers per head is nicked up-purely cosmetic should work w/o any problem) and one head top deck sidewall has tiny dent causing high spot on the top of the deck where the valve cover lays on. all u have to do is sand it down flushed to the surface. If we come to a agreed price i may sell it to you. The dual spring alone i saw on e bay costs $400.00. pm me if interested.
I have a Set of 243 Heads, also with the Manely Dual Coil Springs, Titanium Retainers,
New Guides, Locks, Keepers, and Seats... good for up to a .650 Lift. I pulled them off
and replaced them with a set of AFR .225's. I am asking $550.00 for the set, plus shipping.
I will ship them in seperate boxes to prevent them from damage.
Only looking to sell them as a set. Let me know if you are interested.
You'll need your Rocker Arms. I transfered mine over to the AFR's.
