AC Delete
Old 01-14-2008, 08:21 PM
Ilikeppie's Avatar
Default AC Delete
so i searched this topic before i posted but there are no new discussions i was wondering about the ac delete i hear you gain no hp but loose weight i was wondering what all you need in order to delete the ac?
Old 01-14-2008, 08:29 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
You should be able to find some more info in the Drag Racing tech section
Just a thought
Old 01-14-2008, 08:38 PM
chuckyt1's Avatar
If you're just pulling the AC I don't think there is anything you need, (i also removed the heat when I did it). Just get in there and start pulling it. Make sure you relieve the pressure before you pull the lines.
Old 01-14-2008, 08:39 PM
1320 killer's Avatar
The only thing you need to order is the a/c delete panel to cover the hole in your fore wall. Your right you don't gain hp but you drop something like 41 pounds.
Old 01-14-2008, 08:42 PM
Ilikeppie's Avatar
can i do it and keep my heat?
Old 01-14-2008, 09:05 PM
chuckyt1's Avatar
Yep, if you just pull the AC parts and keep the heater hoses running from the water pump to the heater box the heat will work fine. Removing the heat is pita, AC is a piece of cake...
Old 01-14-2008, 09:59 PM
Ilikeppie's Avatar
to keep the heat and remove the ac i just need to pull the ac stuff and get a block off plate like the BMR ac delete plate?
Old 01-14-2008, 10:04 PM
waterbug1999's Avatar
Yea... I just used a grinder and and cut all the platic crap off along the fire wall. I made my own plate and scrwed it to the firewall then sealed it up. I still have heat.
Old 01-14-2008, 10:27 PM
Ilikeppie's Avatar
good work looks great i guess thats what mine is about to look like!!
Old 01-14-2008, 10:39 PM
Its alot of work but it sure does make changing the spark plugs a hell of alot easier!!
Old 01-14-2008, 10:48 PM
chuckyt1's Avatar
Look how easy those plugs are to get to...
Old 01-14-2008, 10:55 PM
Ilikeppie's Avatar
damn the engine bay looks a hell of a lot cleaner too!
Old 01-14-2008, 10:56 PM
bww3588's Avatar
waterbug, did you have to take the evaporator out from under the dash or under the hood? so you just cut the box and pulled it out that way? never thought about that, the only thing i got left is the evaporator.
Old 01-14-2008, 11:04 PM
Evaporator? UUmm, what piece is this? Can you describe it to me.
But, I do know that all was done from under the hood.
Old 01-14-2008, 11:16 PM
sixvi6-camaro's Avatar
interesting.. What is in that plastic box anyhow? I may have to do the same as I have all the rest of my AC components long gone but I still have to have heat. I like that being totally open on the pass side without that plastic box there.
Old 01-14-2008, 11:32 PM
Whats inside the back box is the AC condensor I believe is what you call it. I have a pic somehwere of me tearing it out.. Ill try and find it.
Old 01-15-2008, 12:41 AM
djsanchez2's Avatar
Nice, This is perfect!! I think i will copy your set-up Waterbug.
Would i be able to use a small cut-off wheel to cut the box off at the firewall?
Old 01-15-2008, 12:48 AM
Its pretty easy.. I still got heat. Just dont cut the little vacum line, thats what controls the ability to go from vents to floor, etc..
Old 01-15-2008, 06:21 PM
Ilikeppie's Avatar
so how did you get the plastic box off the fire wall i was lookin at mine today and it looks impossible how is it attached?
Old 01-15-2008, 07:04 PM
I just cut that bitch off flush with the firewall... There are some tab lookin things around the edge, I cut them off as well to make the cover piece fit flush.
Quick Reply: AC Delete
