what is the deck height on a 408/?
Old 01-14-2008, 10:09 PM
xdanny510x's Avatar
Default what is the deck height on a 408/?
does anyone know what the deck height on a 408 is?
Old 01-14-2008, 10:31 PM
Drew04GTO's Avatar
I believe the deck height of all LS motors is the same. 408's have a much higher piston pin to accomodate the difference in stroke length. Can't remember the deck height of an LSx crank centerline to top of deck, its a fairly available number though.
Old 01-15-2008, 08:01 AM
WeberRacingEquipment's Avatar
The deck height can change from build to build. Alot of this will depend on the piston specifications and the specifications for the build. Usually whoever builds the engine should have that on file. We stamp the deck height on every block we machine.
Old 01-15-2008, 09:07 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Standard is 9.24" on an LQ9/4 iron block. But again, check with your speed shop or machine shop to see if the block has been decked any more to be sure!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Quick Reply: what is the deck height on a 408/?
