I bought a ls6 intake off a blown motor!!
Old 01-15-2008, 10:48 AM
Ls1Gummi's Avatar
Default I bought a ls6 intake off a blown motor!!
I recenlty purchased a ls6 intake off a motor than blown clean up! Is there any kind of way i can get all that debri out of there and not have to worry about some debri still stuck in there or something. I soaked the intake in parts cleaner several times and i use a shop vac and a air blower to flush that stuff out. Should it be fine???
Old 01-15-2008, 10:51 AM
TheLS1Kid's Avatar
Can you visibly see any **** in it?
From the sound of it you should be fine with the soak and compressed air.
Old 01-15-2008, 11:05 AM
1320 killer's Avatar
Sounds like you did exactly what i would have done. It should be fine. good luck.
Old 01-15-2008, 12:11 PM
Ls1Gummi's Avatar
Nah i dont visibly see anything in there anywhere. I'll post how it went when i get put it on this weekend.
Old 01-15-2008, 01:01 PM
slt200mph's Avatar
Get a piece of wire or a coat hanger spray a little brake clean on it and pull it rag though the intake runners and you will get it clean...if you are worried about anything still in the intake runners get one of those little mirrors on a swivel and look up into the runners and check them out ..
Old 01-15-2008, 01:28 PM
BLACK2001SS's Avatar
I think you did it right with the cleening solvent as long as it was the kind of stuff you get from saftycleen nothing too nasty. Anythig stronger on plastic (basicly is not good to use) like brake cleen maby a little wont hurt but that stuff eats plastic.
If your worried send it off to tpis and have them make it a 90mm they will cleen it out good for ya.
Old 01-15-2008, 02:47 PM
99mongooSS's Avatar
I would have done the soak down and air just like you did.
Old 01-15-2008, 03:11 PM
slt200mph's Avatar
You can't hurt a Z06 intake with brake clean...if you could mime would be phuched up beyond beleif..I cleaned it inside and out with a ton of brake clean before I sent it to the body shop to be painted...it looked like it was brand new when I finished cleaning it up ...
PS NEWS FLASH ... The intake is not made out of plastic
Old 01-15-2008, 03:13 PM
99mongooSS's Avatar
polymer right?
Old 01-15-2008, 03:44 PM
Russ K's Avatar
This is the GM TSB.
Russ Kemp
Attached Thumbnails I bought a ls6 intake off a blown motor!!-clipboard01.jpg
Old 01-15-2008, 04:04 PM
If you have a saftyKleen parts cleener its a ok way to go Brake CLeen takes paint off and yeah it might be a polymer stronger than plastic but I just wouldent use it to cleen out an intake, SOAP and WATER is realy what recomended.
but you can use what ever you want on a Z06 intake I'm goiong to use whats safer on my LS6 intake.
Old 01-15-2008, 04:23 PM
LS1>girlfriend's Avatar
the intake manifold is made of nylon.....
Old 01-15-2008, 04:49 PM
In the restor kit all it says is that the intake is made of a composit.
INTAKE MANIFOLD (GM restor kit 2001)
" The IAFM or integrated air fuel module is a one peice composite design..."
kkslds's Avatar
Since when is there a difference between a Z06 intake and a LS6 intake. They are the same thing.
Nylon is a form of polymer. So the intake is polymer just like everyone elses.
As far as I can tell you should be fine. Whether you use the method you did or brakecleen it should be fine. If you don't see anything or feel anything it's good to go. Blow the runners out good and put it on. Now whether or not brake clean removes paint is irrelavant since the ls6 isnt painted black. This shouldn't be that hard. Dunk it in some soap and water and swish it around and blow it out. Done.
Old 01-15-2008, 04:52 PM
kkslds's Avatar
a composit of everything it takes to make polymer
Old 01-15-2008, 05:00 PM
slt200mph's Avatar
LS6 intake ... Z06 intake ... 2001-2002 LS1 intake ... they are all the same ... all I know is that I have used brake clean on a mine and many others and they all cleaned up great which was the results I was looking for .. there was no paint on them to damage ... I was trying to get them clean enough to paint them ... everything that you see in these photos that was painted Navy Blue Metallic got cleaned throughly with brake clean before going to the paint shop ... I rest my case ..
Old 01-15-2008, 05:06 PM
Well I think that you would confuse people if you said you had a Z06 intake its like saying I have a camaro intake well which one was it haha I'm just pickinig on the guy no hard fealings.
I guess the one thing that I would be concerned about is that hot metal peices can melt right into the composit materal, you do need to go threw it.
And the reason I say no to brake cleen because that stuff will eat seal and everything else like the kind of seals that are used to seal your intake and no the intake is not painted black but isnt it knda common sence to not use somthing on a composit that eats threw cleer coat ? I just dont want some kid thinking its Ok to use Brake Cleen for a multi purpose cleener its made to cleen brake roaters and stuff made of steel.
Old 01-15-2008, 05:08 PM
Intake looks nice bet you dont use brake cleen on it now.
Old 01-15-2008, 05:15 PM
composit is a very vague answer. ls1 and ls6 intake manifolds are made of nylon, look it up.
plastic is a polymer too, so your really not proving anything.
Old 01-15-2008, 05:26 PM
99mongooSS's Avatar
Hope you get it cleaned and on your car succesfully. Good luck, and dont break the oil sensor in the back...hahaha!
Quick Reply: I bought a ls6 intake off a blown motor!!
