stock tire or not
Old 01-15-2008, 06:40 PM
neals98's Avatar
Default stock tire or not
Would i see a diff time at track from changing from stock wheels to drag lites.
Old 01-15-2008, 09:48 PM
CRAZZ28's Avatar
Yes. First you will reduce unsprung weight because drag lites and pro stars are very light. And reduce rolling resistance with the skinnies up front. You will also get better traction with the 15" rim because you can run more sidewall in the tires.
Old 01-15-2008, 10:59 PM
Camaro396's Avatar
yes especially if your spinning and put good tires on. I went from 14.2s to 13.7s going from 17" wheels to draglites with et streets on my mustang.
Old 01-15-2008, 11:08 PM
OSUBraden's Avatar
^Twin turbo's help too
