FAST 78 Question
it was new. I checked all vacume lines. It may have been the MAP sensor, but anyways I took it apart, the MAP is new but it had a good whistle to it, the quetsion I have is would it be alright not to put the o ring in and instead seal it with some hi temp silicone?
I'm shure it would seal problem is that if you put too much on and it pushes out then you might have peices of junk going inside your engine which I wouldnt feal comfortable with I'd just use the oring.
