P245/50R 16 Tires???
P245/50R 16 This is what my local tire place said would be the widest that I can fit on my stock snowflakes. I dont really know what this means as far as wideness and such. Is this a good size? I need a little Tire ED. please.
Thanks for any input
-Jake
-Jake
ok thanks guys. Ill just stick with the crappy tires I have now till I can afford some 17x9.5's. I just figured if I can find them I would just get 2 to hold me over till the spring.
((((((Administrator))))))
We do have a Wheels & Tires section:
https://ls1tech.com/forums/wheels-tires-17/
Read the sticky threads and try a search!
LS1Tech Administrator
Received 1,462 Likes
Yes, 255 will fit just fine. Dunlop also makes a 255/50/16 tire.
if a 275 will fit the fronts....a 255 will fit
a 255 tire will have 3/8" wider tread....which will have NO noticable affect on traction...assuming identical tires. its the style tire that makes more differnce.
i had 255 series Firehawk SZ50s on my 96 z....love them.
theoretically the tire will be about 1/4" taller as well...which could will throw your speedo off by 1.5%
Summito makes a great 245/50/16 that is 9" wide for $63.00. Check with the Tire Rack , they may even make a 255 series in a 16". Also BF Goodrich makes a 295/50/16 .
There aren't a whole lot in 255's but they do make MT Drag radials in 255/50 r16 if you really want to hook. MT's are wayy stickier than BFG's. Here is a pic of my car on 255 Dunlop's on stock snowflakes. No rubbing problems or anything with them on my car.
