Best Bolts On for an LS1!!!!! Lets make a list with dyno proof.
I have 2001 firebird A4.
mods: 212/218cam, SLP maf, slp cold air intake, ported thrttle body, lt flowtech headers.
350rwhp 407rwtorq
What other bolt on you recommend???
1.8 Rocker arms???
Exhaust system???
Intake manifold, biggar, fast 90/90???
Throttle volt booster???
ETC....
WICH ONES ARE THE BEST????????
350rwhp 407rwtorq
1.8 Rocker arms???
Exhaust system???
ETC....
in general there is no "best" .. different mods are geared for different setups. it depends on the way the car is set up and the way the driver intends to use the car (street, strip, etc).
1.8 rockers will definatly help your cam out. with the flow potential of the lsx heads...why NOT go for more lift. figure about 10-12hp for the swap.
underdrive pulley is fairly easy to install and will net 5-10hp
with that cam and stock heads, the FAST intake is overkill...keep the LS6. or wait for the new intake to come out this spring.
you don't list an exhaust setup other than headers. a good free flowing system can free up good power. at least get a cutout.
Retired Street Racer
Here are my boltons. My times in my sig were without the water pump, new tune, and 225lbs heavier. It should be 10.80-10.90 come spring time. Go to my homepage for more info.
Stainless 1 3/4-inch longtube headers
Magnaflow mufflers dumped off of the collectors
Fast Toys 85mm air lid
GM 85mm Z06 MAF sensor
Ported 90mm LS2 intake
PTM 90mm throttle body
Powerbond 25% underdrive crank pulley
Custom ram air induction
Meziere drag electric water pump
MSD 8.5mm Super Conductor plug wires
anything that touches oil isn't considered a bolt on so rocker no and forthe price of rockers you can buy a cam and pushrods and almost some springs LOL
i have seen 16-19whp with ASP pulley and ported stock TB
350rwhp 407rwtorq
1.8 Rocker arms??? probly not. go bigger cam insted caust for parts is the same almost.
Exhaust system??? cut out or cut OUTS
Intake manifold, biggar, fast 90/90??? or send your ls6 to tpis for a 90 300 and get a 90 tb 450. fast = $1400
ETC....
350rwhp 407rwtorq
ETC....
just my thought on it, that cam is pritty small but dosent mean that it wont work well I'd probly go bigger though.
Thanks man
Quadd
Are you rocking a cage in that thing or are you going to possibly get booted too like me...
no more big boy ram air intake for you...
pm me if you are still interested in a huge one like i got...
damn i gotta drop some weight off this beast or i am not going to be able to keep up with you cam only...
I would be interested in the Ram Air. It's bigger than mine? PM me so we can discuss.
