Need valve locks +0.050"
Here's an example from the Dart 225cc head install that I completed 2 weeks ago.
I had the Crane 144833 spring/retainer/lock kit on my stock heads and wanted to use these on the Darts. I got different installed heights when I used each vendors (Dart and Crane) locks on the same valve with the same retainer and spring seat. The difference was .025" taller installed height using the Dart locks. So I ended up using a combination of Dart and Crane valvetrain parts to get the installed height I needed.
Bottom line, it's a crap shoot how much installed height you will actually get from +/- .050" locks unless the reference and new locks are from the same manufacturer.
Clear as mud?
