Generation IV External Engine - How much rwhp are you ls7 NA guys making these days
landonew
01-17-2008, 08:23 PM
Love the new z06s, and was wondering what you guys where making w/ H/C on stock cubes (as if 427CIs ain't enough). Was thinking of getting a Z after law school (meaning after I pay back the loans so they don't chop my legs off) for the DD. Course by then there will probably be a C12 z06!
ramairws6
01-17-2008, 08:31 PM
I'm running (was running) 535 RWH and 493 RWT with my forged LS7 in a 2001 WS6 Trans Am A4. It's tore apart right now getting more stroke. This HP stuff is addicting!! Traver
landonew
01-17-2008, 08:52 PM
NICE. More Stroke??? How long has the new block been under the hood?
ramairws6
01-17-2008, 09:59 PM
I had about 20 track passes and maybe 2500 miles. I always want to be on top in my neighborhood and there's a '74' Dart that's a real pain in the arss! It's pretty well a racecar, tubbed, lexon windows and 14.1 comp..........all that good stuff but I'm still gunning for him! Good clean fun and it keeps the blood pumpin and the heart healthy!! Traver
ramairws6
01-17-2008, 10:01 PM
Oh ya, I'm putting a 4.125 stroke in it and porting the heads some more not to mention a couple other little tweaks!:devil:Traver
landonew
01-18-2008, 02:43 PM
Damn!! Makes me wish I had gone w/ a stroker package. Whats the best ET? MPH? Any videos?
Zach@MTI
01-18-2008, 03:00 PM
We have built a 611rwhp LS7 in a C5. We have built a few cam only 580+rwhp C6Z06's.....our standard smaller LS7 cam which is pretty mild-med usually does about 540 to the tire. With the right cam and heads the LS7 is capable of big power.
Zach
03 BUSA
01-18-2008, 03:32 PM
Look at sig for info.
slow trap
01-19-2008, 09:38 AM
check the corvette forums,lots of 427 mills in there. the qm600 cammed 427s with ported heads/intake are putting around 600 to the ground.
mikey
01-19-2008, 11:20 AM
570's up to 612 rwhp...
STROKER R/T
01-19-2008, 12:32 PM
no flames to any one tuner !!! however you may fine some big hp 550 to 600 rwhp bragging ### s with no track slip & weight to back the hp !!! claim !!!! i've had 525 rwhp 427 & 560 427 ...dynos some times ..make your track slip ..a puzzling thought !!! my 427 best on NO2 TUNE 10.6 127..OTHERS SAME COMBO & parts 9.9 132..hope this helped
ramairws6
01-19-2008, 01:16 PM
I'm not embarrassed to say my track times at 535 RWHP. I was running 11.1's in the quarter and cutting 1.49 60ft times on Nitto drag radials and a hefty 3,820 race weight. I could never launch off the line more then 2000 RPM's cause my Nittos would bust loose everytime! If I would of had some Bogarts and drag tires I would have definately broke the 10's. Check out my video in the 11 second section of the board. Traver
bandit1
01-19-2008, 05:41 PM
nice video traver just went and saw looked good
ramairws6
01-20-2008, 07:29 AM
Thanks Bandit1.......and believe it or not this was before my QM600 swap so I definatley know the 10's were there! I will never know now though? Got to start all over with the 441. I hope I don't go backwards!? :eyes:Traver
bandit1
01-20-2008, 09:34 AM
you'll do fine boss have faith my brothera hahaha looking forward to seeing this thing come together keep us updated
ramairws6
01-20-2008, 10:22 AM
Do you know why Rev Extreme claims only the 95 mm TB will fit on the lS7 intake?
bandit1
01-20-2008, 02:47 PM
Have no clue i have the 100mm on there and it fits fine I will say that it is just barely and i can see the edge of my seal but its sealed just fine. maybe they mean that the 100mm will just barely fit I dont know
RC45
01-20-2008, 08:01 PM
Well - I for one am preventing one such tuner from posting drag strip time slips... as I didn't have my 600rwhp LS7 car built to thrash down the 1/4 miles strip, but rather beat up around a road course.. ;)
The last thing I feel like doing is blowing the stock 2001 rear end on my car "proving a point" :)
ramairws6
10-12-2008, 12:50 AM
Just to update since my 441 build is done. I'm now at 564/516 at the rear wheels. It doesnt' seem like much more but through a 4L60e and a Ford 9" I don't think it's too bad since I did run a 10.46 at 131 MPH the first time at the track. Also got a 6.4 at 110 MPH through the 1/8th before I got the boot for not having a bar! :bang:Traver
chieftransam
10-14-2008, 11:09 AM
Are the 427's you guys are building streetable? I'm looking to go either 416 or 427. I'm leaning towards 416 since I'm told I could still use a little spray or boost. I'm told the 427 isn't really for boost or spray. Any input?
Stang's Bane
10-14-2008, 11:24 AM
If you build a 427 out of a 4.065 bore block, then yes that is good advice. but if you build it with a 4.125 bore, then you shouldn't have any problems doing some spray or boost assuming it is built with whatever you want in mind.
ss dave
10-14-2008, 12:11 PM
I have a very streetable LS7 430. 502whp on a Dyno Dynamics in a very hot (>100) shop.
njc.corp
10-15-2008, 02:42 AM
Mikey i see in your sign that u have a 675 rwhp on a 427 ls2- soild roller-
is that a street engine or a race motor only-
i am in the middle of working out which to go soild or hydro-
just want to know if it;s a streeter of how the soild reacts to street conditions
Any help would be nice-
Thanks
jason99frc
10-16-2008, 01:46 AM
Not an LS7 but good info for you more budget oriented guys.
My setup:
LS2 block
Darton 4.125 sleeves, Lunati 4.0 Crank, Oliver 6.125 rods, Wiesco Pistons
LS6 TSP stage X heads w/ Alum rockers, Unported Fast 90 & unported LS2 TB, 85mm Maf, Comp 248/254 601-610 112 cam
511rwhp/480 rwtq
Crank and rods are a little pricey but they dont have to be.
Planning on shooting for 600rw n/A ~ December with an LS7 Head/Intake/TB/maf/UD pulley upgrade. Gathering parts now as deals arise.
11.3 @ 128 on Nitto's w/ a 1.87 60 foot. Easy drive away from the tree launch didnt floor it until 2nd about 100 feet out. Has a 10.7 ish in it on good tires without totally abusing the car.
2001 Z06
DBN
10-16-2008, 07:52 PM
My pump gas LS7 was making 545 rwhp and 497 rwtq and ran many 9.9 passes with a best of 9.93@136.90 in my A4 C5. I have since changed to a different cam design but have not gotten a fulll pull on the dyno as the tires continued to break loose as I squeezed the throttle open. The new camshaft made 35-40 more rwhp down low and 25-30 more rwtq but I had to let off at 5800 due to tire spin.
corvet786c
10-17-2008, 04:58 PM
I see hp #'s but where is all the torque. That is what moves the car. The TQ is what gets a better et.
Deeavi
10-17-2008, 08:43 PM
My LS7 Block based 427 made 485 rwhp/485 rwt on the first dyno tune. It is 98% street. AC and all the extras. The comp cams cam that I had was a pain to get the idle right on, so I have since changed the cam to a Lunati VooDoo (less overlap), but have not had it re-tuned. It feels a lot stronger and is scary on the street. It sure is a lot more fun to drive now. The tune is not far off, but I am going to get it dialed in and dynoed again soon. Have not taken it to a track yet. Maybe later.
89Formulaws6
10-22-2008, 10:00 PM
the guys with the 4.125 stroke does anything special have to be done for that big of a stroke?
Mr Z51
10-30-2008, 12:51 AM
How about Ragin Racin. They don't play. Realistic numbers and times.
551hp and a 10.62
http://www.youtube.com/watch?v=Pbglo-IUtD0
