i have 2 oil pumps, which do i use?
Old 01-17-2008, 09:30 PM
KingSumthn's Avatar
Default i have 2 oil pumps, which do i use?
i just bought an ls6 long block to replace my blown ls1. im also installing a g5x3 in the ls6. i have a ported tsp ls6 oil pump on my ls1. should i take it off and put it on my new ls6 or should i just use the new stock ls6 that came with the block? i dont know if maybe both have certain advantages because i heard higher oil pressure robs some hp. so assuming the stock ls6 is fine maybe id just leave it. any opinions on this?
Old 01-17-2008, 10:45 PM
405HP_Z06's Avatar
I would rather use the ported pump, but seeing that it came off of a blown engine I would disassemble and inspect before using. If there's nothing wrong with it, use it.
The best option would be to port the new pump and use it.
Old 01-17-2008, 11:28 PM
KingSumthn's Avatar
yea the reason im asking is just incase my ported one has anything wrong with it after the motor went bad. i guess what i really want to know is would the stock ls6 be sufficient if i had no other pump? or would most people not trust it
Old 01-17-2008, 11:41 PM
405HP_Z06's Avatar
No problem with using a new LS6 oil pump.
Old 01-17-2008, 11:49 PM
KingSumthn's Avatar
thanks you pretty much solved my dilemma
Old 01-21-2008, 09:31 PM
smokeyrider05's Avatar
port the ls6 pump
