How many times can ARP head bolts be whored?
Old 01-17-2008, 09:58 PM
Dirty 30's Avatar
Default How many times can ARP head bolts be whored?
I have some ARP hex head bolts and have re-used them only once after the first time. They are now off and im wondering if I can re-use them again?
Thanks
Old 01-17-2008, 10:12 PM
chrs1313's Avatar
yes you can.
Old 01-17-2008, 10:47 PM
405HP_Z06's Avatar
Thanks
Yep, sure can. ARP are not torque to yield.
Old 01-17-2008, 10:49 PM
Dirty 30's Avatar
i just counted my bolts and realized I have lost one of the medium sized ones
Old 01-17-2008, 11:02 PM
1BadAction's Avatar
call ARP they will sell individually.
Old 04-02-2008, 10:35 AM
mikes99corvette's Avatar
Summit racing will sell them as well
Old 04-02-2008, 10:50 AM
Internet Mechanic
BlackScreaminMachine's Avatar
You can reuse them infinitly if needed. Since they are so cheap, in comparision if you bought a new set every 3-4 times used, it isnt hurting you either.
Old 04-02-2008, 11:08 AM
prochargedchevyi's Avatar
Technically, you can use them as many times as you want, but personally, I like to change mine out every 3-5 applications. I know it's overkill, but I'd rather have the peace of mind.
My rational is this - most torque wrench's accuracy are within +/- 3%-4%, so different torque ratings change per application - depending on how your wrench was feeling that day. Hardware fatigue (either by manufacturing or improper installation) is the #1 cause of blown engines, so I never chance it.
Vince
Old 04-02-2008, 11:34 AM
Internet Mechanic
Vince
Exactly
Also make sure you use the lube from ARP for accurate TQ specs and before reinstalling, blow out those bolt holes.
Old 04-02-2008, 07:50 PM
Dirty 30's Avatar
A little old but of great help! I think I may have to remove my heads again (engine is still on stand) because I didnt clean the holes well enough and I didnt reinstall 2 dowel pins.
Old 04-02-2008, 08:32 PM
Randy WS6's Avatar
ARP is the last head bolts youll haft to buy
Old 04-02-2008, 10:57 PM
2 fast motorsports's Avatar
keep using them over and over
Old 04-02-2008, 11:07 PM
bsf
bsf's Avatar
Please tell us you did not crack the block w/ hydraulic pressure.
