LQ9 iron heads? Big boost and no head lifting?
Old 01-18-2008, 09:31 PM
BIG BAD BLACKSS's Avatar
Default LQ9 iron heads? Big boost and no head lifting?
I think I remember hearing about iron heads on the early 6.0 motors? Im not nuts right? Just wondering if there is a good flowing iron head with big boost if it may be a better option then an aluminum head that will lift and leak coolant.
I've been thinking about adding a nitrous shot to my D1SC 370 Iron blocked setup, but head it seems ill have issues with the heads lifting with big boos alone let alone with spray. Would the iron head be a good cheap upgrade?
Old 01-19-2008, 03:25 AM
black98ws6ta's Avatar
We tested iron heads back to back with aluminum heads and they lifted at the same rwhp.
Old 01-19-2008, 06:47 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Even ported they do not flow as well and they soak more heat since iron have a higher thermal constant.
Keith
Old 01-19-2008, 09:01 AM
cablebandit's Avatar
n/a they should make more power. I am surprised they lifted at the same time though
Old 01-19-2008, 03:55 PM
FootLbs's Avatar
And what HP was that might I ask?
Old 01-19-2008, 04:00 PM
A long time ago when 740rwhp was alot...the hp level at which the heads lift will depend alot on the turbo, kit, tune. Technology on the matter is alot better now.
Old 01-19-2008, 04:03 PM
FootLbs's Avatar
Do you feel with higher compression you are more likely to lift your heads? Even with comperable power levels..
Old 01-19-2008, 04:21 PM
Thats weird the heads lift at the same levels the aluminum did. Makes me think its some other sort fo problem. Id imagine the iron heads would be much more resistant to lifting. Are the head bolts just stretching?
Old 01-19-2008, 04:36 PM
FootLbs's Avatar
He said that it was a while ago when 740 was big numbers, so my guess is that the rod bolts werent that advanced... ex. new ARP L76 bolts and the other one... that corrodes... (cant remember name)
Old 01-19-2008, 08:59 PM
Mr.MartyStone's Avatar
Yeah try again, Head studs have been around for a while and if you're lifting a stock casting at 740rwhp it is most likely in the tune. The studs you're referring to that are subject to fatigue when in contact with moisture are L19's.
Quick Reply: LQ9 iron heads? Big boost and no head lifting?
