General LSX Automobile Discussion Non-technical LSX related topics.
Ignition Question
Old 01-19-2008, 12:59 AM
Rushin's Avatar
Default Ignition Question
I just got a 2002 Z (blah blah blah pics I know... I'll post them tomorrow ) and was wondering how hard it is to replace an ignition lock cylinder.
Old 01-19-2008, 12:41 PM
bryan04h's Avatar
it is a lil pita but if ya want some directions, i think this will help ya out
Removal Procedure
1. Remove the inflatable restraint coil.
2. Insert the ignition key into the lock cylinder.
3. Leave the key in the LOCK position.
4. Remove the lock retaining screw (2).
5. Remove the lock cylinder (1) and harness (4), perform the following:
- Disconnect the terminal connector from the bulkhead connector.
- Remove the wiring protector.
- Disconnect the retaining clip (3) from the lock housing cover sleeve.
- Gently pull wire harness (4) through the column.
- Remove the lock cylinder (1) from the vehicle.
Installation Procedure
1. Install the lock cylinder (1) and harness (4), perform the following:
- Install the lock cylinder (1) to the vehicle.
- Connect the retaining clip (3) to the lock housing cover sleeve.
- Install the wiring protector.
- Connect the terminal connector to the bulkhead connector.
2. Install the lock retaining screw (2). Tighten the lock retaining screw to 2.5 N·m (22 lb in).
3. Remove the ignition key from the lock cylinder.
4. Install the inflatable restraint coil.
Old 01-19-2008, 03:13 PM
Rushin's Avatar
That helps a lot. Now do I have to get a key programmed at a dealership?
