will ls1 head fit 5.3 block?
Old 01-19-2008, 08:25 AM
sr_ryan1's Avatar
Default will ls1 head fit 5.3 block?
i konw 5.3 head fits 5.7 but does 5.7 fit 5.3?
Old 01-19-2008, 09:46 AM
FIREHAWK#608's Avatar
Default 5.3?
Yes the should work just fine. All the LS based engines parts are pretty much enterchangable except for the LS7.
Old 01-19-2008, 11:34 PM
smokeyrider05's Avatar
yup. it should work no problem.
Old 01-20-2008, 09:09 AM
Shawn @ VA Speed's Avatar
keep the 5.3 heads,the smaller bore shrouds the valves too much in the 5.7 heads,not only that you lose compression
Old 02-11-2008, 07:07 PM
fireredz28's Avatar
yeah dont ditch the 5.3l heads....the ls1 heads on the 5.3l block will hurt you in performance unless your going to supercharge it or do anything else to up the compression.
Quick Reply: will ls1 head fit 5.3 block?
