Drag Racing Tech - 33 spline Gun drill?
SSPerformance
01-19-2008, 09:48 AM
Can you gun grill 33 spline axels? or will they be to weak. What kind of weight savings
Top Fuel
01-19-2008, 12:54 PM
I believe Moser will, but Strange will not
mrdragster1970
01-19-2008, 03:16 PM
Never seen any that small myself. Probably smarter to just call moser, williams & strange.
mzoomora
01-19-2008, 03:24 PM
Its only a few lbs weight savings, and although it is rotating mass it is also the very center of the axle which is easiest to turn. If you are looking for the very last lb, then it may be worth it.
JL ws-6
01-19-2008, 03:45 PM
You can get them from Moser, Sean checked for me this week when he was ordering my gears and spool. This way if I have an axle go, at least I know I can get them.
NRC-Motorsports
01-19-2008, 05:59 PM
moser sells them, but we had 33 gun drilled in wagon and twisted them in 8 passes,,but havin 3700lbs ,60 foot 1.32 on the back wheels might have had something to do with that, went to 40, havent checked them yet:nod:
http://i2.tinypic.com/853du0m.jpg
SSPerformance
01-19-2008, 06:30 PM
moser gundrilled star end are 9.5 lbs lighter 520 with bearings. not shure if im gona yet
mrdragster1970
01-20-2008, 10:07 AM
Cool wagon, you're safe, you won't hurt a 40 spline, even at your weight.
That thing is frigging badass. Nice job.
RAGENZ28
01-20-2008, 05:42 PM
I wouldn't gun drill a 33 spline, smallest would be a 35 spline as far as something I would have gun drilled and run myself.
NRC-Motorsports
01-21-2008, 08:56 PM
thanks, here,s a little vid if it works,motor pass
http://www.youtube.com/watch?v=gFbqn4IFw2w
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
