View Poll Results: Keep the Bullets or go spiral flows?
Spiral flows
20
74.07%
Keep the 10" bullets
7
25.93%
Voters: 27. You may not vote on this poll
10" bullets or Spiral flows?
Old 01-19-2008, 01:54 PM
bmxer8699's Avatar
Default 10" bullets or Spiral flows?
I'm looking to quiet the car down a little bit and i currently have the 10" bullets on my TD setup. will the Spiral flows make much of a difference? any tone change? if so is it better?
Old 01-19-2008, 03:39 PM
Tech Resident
ChocoTaco369's Avatar
Spiral flows will quiet it down A LOT in comparison to the bullets. Plus, IMO, they sound A LOT better. You'll get better sound and more tolerable volume, all at the expense of near zero horsepower. It's a much better option IMO.
Old 01-19-2008, 05:33 PM
lastcall190's Avatar
Clips of spirals in my sig. Before and after cam as well.
-J
Old 01-19-2008, 08:58 PM
bmxer8699's Avatar
^ like the sound of the spirals.. i currently have to wake up early in the morning for work this semester and that sounds is sofucking loud in the morning until the tranny gets warm and the converter locks up
Old 01-20-2008, 01:15 PM
bmxer8699's Avatar
any outside clips without a cam?
Old 01-20-2008, 01:40 PM
Yea I do lemme find them then I'll post back...
EDIT: wait, doesn't the clip in my sig have outside footage?
In any case, http://lsx.streetfire.net/search/spi...1e00bf5670.htm
Old 01-20-2008, 02:42 PM
Dennis93TA's Avatar
That sounds a lot better than my bullets, it's just obnoxious loud and they aren't even dumped!
Old 01-20-2008, 10:53 PM
navyblueSS's Avatar
I just replaced my bullets with the spiral flows about a month ago. It isn't really that much quieter but it does have a better sound to it so I am glad I did the swap.
Old 01-21-2008, 10:42 AM
speed_demon24's Avatar
I have spiral flows right now and I'm trying to figure out how to quiet down my car. I'm wondering if the 17" twisters will do anything noticable.
Old 01-21-2008, 11:49 AM
fastGBcamaro's Avatar
I see people say that the spiral flow doesn't give up any hp to the bullet, but does anyone actually have dyno proof? The only reason I ask is because I currently have the spiralflows on my trudual setup. My car sounds great, but its still pretty f'in loud. It could be because I am running 413 cid with 1 7/8'' headers to a custom 3'' true dual exhaust with a 3'' x pipe. I actully think I might have the only f-body LSx car with true duals w/ x pipe with a chassis mounted torque arm. It took a bit of customization and fabrication. I have been considering putting bullets in place of my spiral flows if it will make more power.
Old 01-21-2008, 11:53 AM
LS7jUnKiE's Avatar
Dude Ive got Flowmaster 1-chambers on my true duals and it is the best sounding set-up I have ever heard IMO. Ive heard bullets and spiral flows and they sound raspy to me...the 1-chambers are DEEP and have an amazing tone to them....and driving conservatively i have no problem driving next to cops, but once you slam the throttle down it sounds like deep growls from the darkest pits of hell!
Old 01-21-2008, 12:34 PM
Do you have a cam? I didn't think the noise would've changed that much after the cam, but it definitely did. My spirals were very deep and subdued at anything but WOT, but now with the cam, it's louder everywhere. Being quiet is a thing of the past. Oh well.
-J
Old 01-21-2008, 12:49 PM
K99Raptor's Avatar
I just changed my spiralflows for some borla 4x9's and I took the piping under the axle to try and get rid of some drone. I REAAAALLY miss the sound and the ***** of the sf's, but my set up now still sounds damn good and it's more practical on the streets and firing up in my neighborhood.
It still is loud at 70mph though. Not nearly as loud, but still loud. If anything, I picked up hp due to magnaflows straight through design.
If you're not trying to go to quite, I would go with some spiral flows, but I would install high flow cats. I'm still considering it on mine.
Old 01-21-2008, 06:46 PM
bmxer8699's Avatar
wow, that does sound alot better..
never considered cats.. would the cats cut back on that damned smell when i roll the windows down? or stand near the car?
Old 01-21-2008, 07:43 PM
FWIW, and maybe it's because I've never had cats on any of my cars and my nose is shot...
...but in any case, cats would cut down on the smell if there was one. I didn't have a smell so I can't really comment accurately. If I were you, and this is what I did, just put 'em on with no cats, and you can add 'em later easily. That way without cats you will know how loud it can be, so when you put cats on you only know it will get tamer.
-J
Old 01-21-2008, 09:41 PM
Reject's Avatar
lastcall was the reason i went with the spiral flows, i heard them on alot of other cars but his was the first time i heard them on a ls1. i've had mine with my ms4 the 226 and now with the current setup. they just have that natural old school hot rod sound and are easy to fit under the car compaired to a full size muffler
Old 01-21-2008, 09:43 PM
Reject's Avatar
BTW i swapped out the bullets on ULTX's TSP TD to some spiral flows and he loves them ALOt, made the car alot more queiter and more definded than the bullets
Old 01-21-2008, 11:51 PM
bmxer8699's Avatar
bullets make my ears bleed at 75. i wore ear plugs on my last trip to austin. plus with the stall keeping the rpms higher the drone is now even worse.
hopefully the SF's will quiet it down.
and how to you add cats "easily" erm.. i dont have a welder.
Old 01-22-2008, 06:08 AM
Reject's Avatar
they do, i have a 3400 stall on mine and it's strange but like at around 75ish the car gets really quiet
Old 01-22-2008, 03:00 PM
If you are considering spiral flows you might want to take a look at the 17" twisters. They said they quieted down their cars 5db over their 12" version, so I'm probably going to swap out my 12" sprialflows for the 17" twisters.
