TR224...what shift points?
i am not exactly sure where to set my shift points with my setup. it is TR224 112, TSP 5.3L 2.5 heads, and full bolt ons including LT's. i find that they are almost always faster when shifting a little late. i am thinking setting it at 6300 or 6400. also, what is a good rpm to set the car to idle at? any suggestions?
Well, it would be nice to see a dyno sheet with your power curve..
..but I would probably be shifting at 6500 set the rev limiter to 6700.
On another note, do you have stronger rod bolts on your car?
If not, you shouldn't really be bringing that car anywhere past 6700rpms..
