Nitrous Oxide - spark plug rec-inside please..........
ls2 bait
01-19-2008, 07:42 PM
heads/ cam. 11.4 static cr 8.4 dynamic cr. 150 wet kit. (throw 200 pills in when i get antsy) 24* of total timing. (but i use 100 octane on the 200)
so tr6 or tr7? standard gap or change em up?
VH5150
01-19-2008, 08:02 PM
Id say 7's (br7ef), gap not too sure...
itsjustaSB
01-20-2008, 01:31 PM
id say 7s and the standard 35 to 38 gap if i remember right, thats the same setup i want to run with my kit next summer ls2 bait if you dont mind me asken what did your car run on the 150 shot
ls2 bait
01-20-2008, 08:20 PM
dont know i never got a chance to run it. started lifting the heads and killed the gaskets so its coming back apart tomorrow.
itsjustaSB
01-20-2008, 09:36 PM
damn that sucks well good luck
GueSS Who
01-20-2008, 10:00 PM
Br7ef
Noyzee
01-21-2008, 07:39 AM
pull a little timming, and add better gas. that will help with the heads some, and i would say run 7's
what gaskets?head studs?
ls2 bait
01-21-2008, 06:36 PM
this time around im running gm gaskets and arp studs. the set up that died was cometic .045's and arp bolts. im going to do the iat timing tricker i think beings my tuner is never around when i need him and i dont run on the gas that often.
itsjustaSB
01-21-2008, 09:14 PM
awww thats not what i wanted to hear thats the same setup im runing well hopfully i get atleast a few runs on hear
JL ws-6
01-21-2008, 09:21 PM
Do yourself a favor, get the software and adjust the timing yourself, thost timing things never seem to really work right and are insconsistant.
BrianC98Z28
01-22-2008, 12:19 AM
Im currently running TR7s gapped at .030. They came pregapped at .025 so i opened them up a little bit. Prior to that I was running TR6s at .035 which is what they come at. I just tried the 7s out this time to see how they do and be a little extra safe.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
