what oil pump and timing chain
Old 01-19-2008, 10:21 PM
hokie00 TA's Avatar
Default what oil pump and timing chain
pulled the motor outta the bird today and finally found out what the knock was in the motor the timing chain was about to fall off it had so much play in it you could move the chain back and forth 1/2-3/4 of an inch so im looking for a good replacement chain and while ive got the motor out and its so easy to replace the oil pump now im gonna do it so what oil pump and timing chain set should i go with.
Old 01-19-2008, 11:12 PM
99 BLACKFIRE's Avatar
I went with a LS2 timing chain and a high flow ls6 ported oil pump. The chain is not double roler but it has thinker links than the LS1 chain and uses your stock cam/timing gears.
Old 01-19-2008, 11:13 PM
badass99ss's Avatar
I just installed a Melling oil pump with a JP performance billet chain. Both seem like quality products, haven't started the car cause I'm still doing my head and cam swap.......and blower.
Old 01-19-2008, 11:28 PM
smokeyrider05's Avatar
ls2 chain and ported ls6 pump.
Old 01-19-2008, 11:30 PM
Fratsit's Avatar
Like others have said....
LS2 chain and ported LS6 pump. I got both from Texas Speed.
Old 01-20-2008, 01:15 AM
LSX Mechanic
Damian's Avatar
LS2 and ported pump is the combo I usually recommend. Simple, cheap, and works great. The LS2 chain is a lot beefier than a stock LS1 chain.
Old 01-20-2008, 01:27 AM
1320 killer's Avatar
Go with a ls6 ported pump and a cloyes double roller chain.
Old 01-20-2008, 03:13 AM
95 Z28's Avatar
I've got no complaints with my ported LS6 pump that I bought off a member here. I also went with the LS2 chain because it's just simple and cheap, and as other stated, a lot beefier than the stocker.
Old 01-20-2008, 07:02 AM
vettenuts's Avatar
Curious, what chain were you running?
Also, how does your cam plate look under the sprocket, they are know for a lot of wear so I went with a new timing set that has a Torrington bearing.
Old 01-20-2008, 08:45 AM
SOMbitch's Avatar
A ported LS6 pump is a nice piece but I like the 10296 hi flow Melling better.
Old 01-20-2008, 01:38 PM
hokie00 TA's Avatar
it was the stock chain and i didnt look at the cam plate.
Old 01-20-2008, 01:41 PM
JPH
JPH's Avatar
JP Performance #5618T timing set, with a Melling #10296 pump.
Eatinstang4life's Avatar
I just ported and shimmed my stock pump works great!! I used the rollermaster double chain also works great!! I did have to grind down my timing cover a little though
Old 01-20-2008, 01:48 PM
NaturalMystic831's Avatar
Won't be long 'till I do my cam swap and I was thinking of upgrading the chain while I'm in there. Will the LS2 chain fit on there with no other modifications?
Old 01-20-2008, 02:05 PM
SmaknaSS's Avatar
How does the LS2 chain compare to the JWIS chain? I the LS2 chain just as strong?
Old 01-20-2008, 02:11 PM
vettenuts's Avatar
Never seen strength numbers between the JWIS and the LS2. LS2 is thicker, but JWIS may be stronger steel. Both have seamed rollers.
Old 01-21-2008, 12:36 AM
SmaknaSS's Avatar
The JWIS is proven chain but I don't hear about people breaking the LS2 chain ether. I may just go with the LS2 chain on my next motor.
Old 01-21-2008, 12:53 AM
BayAreaSS's Avatar
I'm going with the ls2 timing chain and ls6 ported oil pump from texas speed
Old 01-21-2008, 12:55 AM
XSNRGY's Avatar
Hey there dude. I've just done the pump/chain swap too and what a friggin nightmare havin to set up the clearances between the pump body and the drive gear! I also have to modify the cover, can you help us out with where to grind etc? How did you centralise the cover to make sure the seal was dead concentric? Cheers, Mark.
Old 01-21-2008, 10:09 AM
Spacer should come with the kit to space the oilpump. I didnt have any problems with the pump not clearing the gears. For the cover just put it on with like 5 bolts and turn the engine over by hand, then take the cover back off and you should be able to see where its hitting. Little marks will form on the inside of the cover and just grind down those areas I had to grind down like 4 areas esp the little half sphere .
