bigger or smaller cu if going to max out turbo
Old 01-20-2008, 09:07 AM
LS1LT1CAM's Avatar
Default bigger or smaller cu if going to max out turbo
which would be better for a s70 if planing on make as much power as possible
stock cu 365 4.00 bore 3.625 stroke
310 cu 4.06 bore and 3.0 stroke
both would be at least 11 to 1
both would have afr's
Old 01-20-2008, 10:20 AM
engineermike's Avatar
I would go with the 310 or smaller. You'll have to run very high boost to get the advantage of the smaller cid. If you run low boost, might as well go big on the cubes.
Old 01-20-2008, 11:58 AM
LS1LT1CAM's Avatar
need to max out turbo is for class racing recorded in the class is 8.99 with 360 cu no weight break for smaller cu just wondering if there is an advantage to useing a small cu because limited on turbo size
Old 01-20-2008, 12:48 PM
MIEric's Avatar
I wouldnt think so. Run as much CI as you can and as much boost as possible. What are the class restrictions on fuel?
Old 01-20-2008, 12:51 PM
Turbo motors aren't like SC, nitrous, or NA motors. The compressor gets more efficient at higher pressure ratios. You have to run a small engine to get the compressor to its efficient range. That, in turn, reduces exhaust backpressure required and increases power.
The typical 350+ cid V-8 running my T76GTS makes 850 rwhp.
The typcial 180 cid I-6 running the same T76GTS makes 1000+ rwhp.
But. . . you have to be willing to run high boost to get the advantage. Like 30++ psi. However, if you're trying to get max power at low boost (e.g. pump gas), then go with bigger cubes, which is what I did.
Mike
Old 01-20-2008, 01:31 PM
Shawn @ VA Speed's Avatar
i agree with Mike,although i would try a smaller bore with a longer stroke to get the small cubes,turbos like stroke
Old 01-20-2008, 05:45 PM
LS1LT1CAM's Avatar
Mike
that is why i am asking this question
limited to 70mm vp 116 gas
it will make as much boost as it make
how much compression is to much in this appication
heads up as fast as can go
Old 01-20-2008, 06:17 PM
LS1Tech Sponsor
hellbents10's Avatar
Build a 4.8 with stock crank forged rods and pistons. Reliable and cheap! Then run the 70 with the biggest exhaust side you can get.
Old 01-20-2008, 08:16 PM
LS1LT1CAM's Avatar
4.8 crankshaft in 6.0l block makes 330 cu
Have 6.0l block with roller cam bearing 4.003 ready to go
Have eagle H-beam rods with l19 bolt
Have 4.8 crank 10 10
afr heads 205 lots of work flowed 323 at .550 max lift for class
fast 90mm intake worked 80mm tb
how much compression (11 plus?)
s70 in s76 housing with 1.3 AR and t6 flange
would this be good combo or to many cu
Old 01-20-2008, 08:19 PM
Big Geek's Avatar
I wonder what a 4.8 or 5.3 would be like with a PT74 on it. I say go smaller on the displacement!!! I think you would be happier, as mentioned with a 4.8 and that turbo. Just my .02 cents. Take care.
Jim C.
Old 01-20-2008, 08:28 PM
stevensLS1's Avatar
you might want to look into a ls6 intake. ive read that the fast intake isnt good at the higher boost levels. someone correct me if im wrong.
Old 01-20-2008, 09:09 PM
Mr.MartyStone's Avatar
True 70mm or can you run a restrictor? I would run the 310 or smaller, ditch the 6.0 iron block for the aluminum block unless you are already well within the weight requirements of the class.
Marty
Old 01-20-2008, 10:24 PM
LS1LT1CAM's Avatar
Marty
there is a housing size limit and a tip to tip limit
what about 3.00 stroke and 4.00 bore 302 cu
Old 01-21-2008, 08:56 AM
smokinHawk's Avatar
i always felt the other way around, short stroke larger bore as turbos love to spin in the upper Rpms.
Old 01-21-2008, 09:12 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
I'd be curious to see how it would do with the 6.0 block and the 4.8 3.27 stroke crankshaft. I know that folks running in restricted classes will typically run more compression than street cars, but is the average 11:1 in that class? Sounds like that NMRA class.
Old 01-21-2008, 12:10 PM
the secret is to make the long stroke motor rev high,i take my 4'' stroke motor to about 9000 rpms,Ask Steve Petty what he thinks-he loves long stroke motors
Old 01-21-2008, 01:26 PM
LS1Tech Co-Founder
9000 rpms with LSx stuff is gettin' up there, I think most home-built setups could take 8000 rpms with the right oiling system and valvetrain.
Old 01-21-2008, 07:41 PM
LS1LT1CAM's Avatar
have everything to do that but pistons
what do you think?
think this will be faster than 4.0 bore 3.625 stroke 6.0L
most people were running 9.0 to 10.0 to 1 on the 72mm last year
Old 01-22-2008, 04:59 AM
gametech's Avatar
I was just thinking, wouldn't a longer stroke smaller bore combo allow more static compression than a large bore small stroke combo? I'm still not sure if the difference would overcome the extra piston speed problems, but I thought it would be food for thought anyway.
Old 01-22-2008, 08:32 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Same here. Plus the shorter stroke will make a quicker revving motor, which produces faster spool times.
Keith
Quick Reply: bigger or smaller cu if going to max out turbo
