will a 27''-10.5 tire fit a stock 16'' z28 wheel ok?
i have stock 16''z28 wheels and i am puting et street or hoosier quick times on them. will a 27''-10.5 fit ok? or do i need to go with a -9.5'' tire and how well it hook up on a stock suspension 02 zo6 with 845rwhp 1.5 -1.6 60''?
with 850 to the wheel i can imagine your traction issue .
as far as it fitting the stock 16s i think are around 8 inches on the rim so it would not be safe to run that wide of a tire . might want to look for a little wider rim with that power .
if you have not read the sticky a the top take a look as it has some good info on all the tire sizes .
