question for a procharger
Old 01-20-2008, 06:40 PM
dragracer44life's Avatar
Default question for a procharger
my 2002 a4 camaro runs 11.8 all motor.
if i added a 8psi intercooled procharger with 60lb fuel injectors, would my car by anychance run 10's?
Old 01-20-2008, 06:53 PM
allthrotle's Avatar
I would say its a possibility, do you have a stock rearend? what size stall?
Old 01-20-2008, 07:34 PM
EPP
EPP's Avatar
We generally see an increase of 140 rwhp with 8 psi of boost with an ATI ProCharger. The power would be there to get in the 10's, provided the drivetrain and suspension can handle it.
Our '95 LT1 is going to be real close as it is currently getting lightened, and it's only showing 367 rwhp on our Mustang Chassis Dyno. It has a 4000 stall converter which doesn't do anything for dyno horsepower, but it runs 11.31/11.32 at 118 mph consistantly. It is now getting a manual steering rack, ac removed, elec water pump, race brakes front and rear, abs removed, power brake booster removed, etc. We're also swapping in a spool for the eaton posi in the Moser 12 bolt.
You can see the car here, with new pic's soon. http://www.exoticperformanceplus.com...tCar.php?car=7 Bob
Old 01-22-2008, 06:29 PM
yea stock rear-end but when it breaks it breaks. i have richmond 3.73's and a 4000 stall tc
Old 01-22-2008, 08:19 PM
WAHUSKER's Avatar
It should, mine went from 12.1 to 11.1, but if you're still running the stock converter, plan on blowing thru it the first time out.....
Old 01-22-2008, 09:16 PM
02NBMFormula's Avatar
i think that i could have gotten it the night i blew a piston. youll be really close.
Old 01-23-2008, 09:26 AM
rufretic's Avatar
I went from 11.62 @ 116 n/a. Added a D-1 & fmic with a 4.25 pulley, made 13psi and ran 10.10 and blew the stock block. Ran a bunch of mid tens before it blew though. Best trap was 138, I was very impressed with my little D-1.
Old 01-23-2008, 06:32 PM
BLNLS1/RX7's Avatar
No I do not think so.
Quick Reply: question for a procharger
