4.8 to 5.3
Old 01-21-2008, 08:10 AM
neals98's Avatar
Default 4.8 to 5.3
Will i be able to just put a 5.3 in my truck with out having to change anything. I am going to use my coil packs,intake. The motors are out of 2001 models the only diff between the two was the motors. The truck with the 5.3 was totaled but motor is good..............THANKS
Old 01-21-2008, 08:15 AM
jkwalkercchs's Avatar
if im not mistaken u will need a tune because the 5.3 is different
do u have the 5.3 pcm? if so use it
if u have it out go ahead and do a little work to it just my opinion
Old 02-19-2008, 08:20 PM
mjacus's Avatar
2003 Silverado
How involved is it to swap a 2003 4.8 to a 2005 6.0 LQ9 without a wiring harness from doner? And if L60E tranny to L80E is a big job. Thanks!
Old 02-19-2008, 10:52 PM
sawzall wielding director
G-Body's Avatar
everything between the 4.8 and 6.0 will bolt up. I don`t know what will have to be changed to make the 80e fit, probably the driveshaft length and trans mount.
To make the 80e work you will have to change the positions of a couple wires and add a couple wires. You will also have to have the PCM re-tuned to control the 80e and 6.0l
Old 02-20-2008, 09:50 AM
LS1TECH Sponsor
Schwanke Engines's Avatar
I can help you with the tuning.
