Can't get Converter to lock. Please help.
Old 07-07-2003, 09:48 AM
PewterZ28's Avatar
Default Can't get Converter to lock. Please help.
I just reprogrammed for new gears (from 3.23s to 4.10s). The shifts are fine but the converter won't lock in 3rd gear. This is a big problem because unlocked, I run out of rpms around 93 or 94 mph. Unless I want to run the 1/8 mile from now on.
Right now here is how I have it:
1-2 Shift @ 30 mph
2-3 Shift @ 60 mph
3-4 Shift @ 121 mph
2nd: apply at 54, release at 50.
3rd: apply at 74, release at 53.
4th: apply at 110, release at 90.
It should lock at 74 mph in 3rd gear, right?
Derrick
Old 07-07-2003, 03:31 PM
Ed Blown Vert's Avatar
Default Re: Can't get Converter to lock. Please help.
I am confused, why you having it lock at such a high MPH?
Old 07-07-2003, 10:23 PM
PewterZ28's Avatar
If anything, 74 mph is low. The only reason it is so low is because I have 4.10 gears. With 3.23s I had it locking at 95 mph and I was running 11.7s @ 114 mph with bolt ons. Are we thinking about the same tables?
Old 07-08-2003, 12:45 AM
You trying to get it to lock @ WOT??
Old 07-08-2003, 09:56 AM
PewterZ28's Avatar
yes
Old 07-08-2003, 10:39 AM
Ahhh, that makes more sense. Which table are you modifying?
Old 07-08-2003, 11:35 AM
PewterZ28's Avatar
The TCC mph threshold.
I think you just made me realize what the problem is. I have to change those values in those other tables also, don't I? All six of them, though? Also, allow TCC to lock during shift should equal false, correct?
Derrick
Old 07-08-2003, 12:03 PM
I think you should only need to modify the Normal Mode MPH vs % TPS.
