Dual stage dry kit..I've got questions
Im thinking about setting up a two stage dry kit but i have a few questions. What are good rpms to activate stage 1 and stage 2? Also do i just tap 2 more holes (for the second stage jets, I have 2 5177 kits)in the airbox or is there a better way? I have a maft which i guess i'll use for enrichment but will i have to run it really rich to compensate for both stages? I have the timing tuner so i can pull a bunch of timing.
Re: Dual stage dry kit..I've got questions
Nos makes a y-fitting that hold jets in it. You can run 2 of thoes (one for Fuel and the other for N@) and not run any jets in the lid. That and another set of noids with the extra line to run that stuff.
I was thinking about a dual dry shot (fuel handled by the maf reporting the n20). But your brought up a good idea. I could use a wet type nozzle and have each dry stage plummed to the it.....only two holes in the airbox then if i set it up like the 5177 directions state.
