Dual widebands necessary with BS3?
Old 01-22-2008, 03:25 PM
Jimmy P's Avatar
Default Dual widebands necessary with BS3?
I will be getting BS3 for my procharged car. I was curious if the dual wideband option is worth it. I was told its an extra $600. Any responses are appreciated.
Thanks
Old 01-22-2008, 04:13 PM
1INSANEGTO's Avatar
Single Turbo car nope. on procharged car it might be worth it.
Old 01-22-2008, 06:28 PM
OreoLt1's Avatar
I say definately worth it! If you stick a wideband after the Y your reading both banks mixed so if you run lean on one bank and rich on another you won't know. IMO I like the capability to monitor both banks seperatley than getting a rough estimate of the two mixed.
Old 01-22-2008, 06:44 PM
shoemike's Avatar
can the BS3 tune bank to bank/cylinder to cylinder?
Old 01-22-2008, 07:05 PM
Jimmy P's Avatar
I probably wont opt for the dual widebands. I talked to Kurt at W2W and he sayed to just stick with the single.
Old 01-23-2008, 05:14 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I believe so. Someone correct me if I'm wrong...
Old 01-23-2008, 06:22 AM
1INSANEGTO's Avatar
cylinder to cylinder Fast is a Bank to Bank system.
Here is some good reading for ya. http://www.bigstuff3.com/gen3sefi.pdf
Old 01-23-2008, 09:25 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,087 Likes on 716 Posts
I'm running a single wideband.
Old 01-23-2008, 09:47 AM
B18CYA's Avatar
Not to hijack your thread Jimmy p but while we are on the topic I was wondering if any of you use the boost controller option? I have it on mine + wideband but dont know of any that use it.
Old 01-23-2008, 06:05 PM
john_sblendorio's Avatar
Why not just put the o2 sensor at the center of the x on the x-pipe to get the reading? You will be getting an average reading, but unless you have an injector fail or take readings at each cylinder, it should not make a difference.
Old 01-23-2008, 06:56 PM
Jake@EPP's Avatar
A single wideband is usually sufficient for most applications. Just remember to check the plugs to verify the reading, especially lucky #7. With the bs3 you can add fuel or subtract timing per cylinder, EGT would be the best way to get a good tune-up done with but that option is in the works for the bs3.
Old 01-23-2008, 07:22 PM
TT-TECH Veteran
Inspector12's Avatar
Single here with an AEM WB in the other side so I don't have to have my laptop out to watch it etc...
Quick Reply: Dual widebands necessary with BS3?
