spec 3 help
Old 01-22-2008, 06:09 PM
chitownracer77's Avatar
Default spec 3 help
hey everyone i just purchased my 98 camaro with a new ls1 built and the guy i bought it off of said there was a new spec stage 3 clutch he said mabe like 200 miles on it. the thing is that it does shudder like a high performance clutch but the pedal is realy high and its seems to slip bad at about half throttle. i havent jumped on it because its a new engine so im hoping that the clutch needs to break in to. any ideas if this clutch is garbage
Old 01-22-2008, 06:40 PM
LS1Tech Sponsor
Slowhawk's Avatar
You'll have to pull the tranny and take a look.Maybe it's soaked with oil or it's an old beat up clutch in there.It doesn't blow in 200 miles for no reason.
Old 01-22-2008, 06:57 PM
shoemike's Avatar
bleed the clutch
Old 01-23-2008, 11:17 AM
SPEC-01's Avatar
You can certainly try bleeding the hydraulics to begin with. This may fix your problem. You should also check the condition of the hydraulic fluid too...if it is cloudy it needs to be flushed and refilled. After that let us know what you experience. If worse comes to worse you can pull the clutch and email some pics for assessment. I will be happy to assist you with any further questions you may have so just let me know. Thanks!
Old 01-23-2008, 12:10 PM
ok thanks guys thats what i thought im goin to try and bleed it. i just checked the fluid and it doesnt seem cloudy but it seems real thin. i cant do anything untill this weekend when i go home im at collge now. ill post up dates asap
Old 01-23-2008, 01:02 PM
sprayjunkie's Avatar
Dude, for the sake of your feet, pull that clutch before it blows up and destroys your car.
I have seen 2 Vettes get totaled from that POS clutch, and there have been countless others.
Not wanting to take away from the high of owning a nice Z28, but you really should consider this advice.
Do a search here for SPEC 3 and blown up....you will not be happy with what you see.
Old 01-23-2008, 01:28 PM
Bad Blue WS6's Avatar
hmmm, i only got one using that search in this forum.....one thread,,just one..here it is....
https://ls1tech.com/forums/showthrea...=up+blown+spec
not saying that they are all equal, maybe im just lucky,,,but i beat the **** out of mine,, and it hooks like no other i have had. My only complaint is taht its chatty on me when i take off like a normal person.
i always have been an odd ball though...
Old 01-23-2008, 03:40 PM
blue98Z's Avatar
I've had my spec 3 for a year now and haven't had a problem either.
To the OP, just check the easy stuff first before pulling that tranny. We all know about pulling the M6 lol.
Old 01-23-2008, 06:19 PM
LS1Tech Sponsor
Slowhawk's Avatar
Another extremely populer instal mistake is when people reuse the old slave but replace the bearing. There is a spacer/washer that is part of the bearing that will get stuck in the slave.You have to pull it out with a small screw driver before installing the new throw out bearing. If you don't it will act like a spacer and consistantly put pressure on the clutch causing it to slip. I had 1 car that had 4 of them in there.New clutch would not engage at all,then we pulled them out and it worked perfect.
Old 01-23-2008, 06:20 PM
LS1Tech Sponsor
Slowhawk's Avatar
O-ya, clutch explosions.I do remember a group of guy's (2) that blew up there clutches.Just seamed wierd that they were friends and the same person did the installs.We've installed probly 35-40 SPECs throughout the years and never had one come apart.Must be luck.
