LS1 Car Intake Backwards on an LQ9
I have an LQ9 out of an 03 Escalade that is going into a Jeep(ish) project. This motor is TALL.
I'm going to use the oil pan from a Camaro to gain 3.5" at my belly, but I need to bring the intake height down as well... Running a car intake requires the new accessories since it is so much lower profile.
I have heard that an LS1 car intake can be run backwards on the LQ9, retaining the stock LQ9 accessories... maybe relocate the alternator to make it work. You guys heard of this...? Or even better, done it?
Thanks for the input.
Do I need to change out the injectors to make this work? I'd prefer to leave as much stock as possible.
What mods need to be done for this setup to work? How much clearance to I need to the firewall to fit the throttle body?
LS1TECH Sponsor
You will need a complete ls1 intake to do it. The rails and injectors from the truck won't interchange. From the front face of the cylinder head, the throttle body sticks out 3 7/8".
You will still need a way to put the MAF in, unless you are going with a speed density tune, then you would only need the air temp.
Is there a good low-profile air filter that would work well for this application? As far as the tune, I really don't know what my options even are... I am running a full manual valve body TH400 behind this motor & no smog equipment. Any suggestions?
Can I use the truck MAF and/or temp sensor?
Thanks for the great tech.
LS1TECH Sponsor
Well, you can do either. Do you have the harnes and computer yet? If not, we can get you set up with it. How far are you into it? We have kits, harness, comp., fuel pump, lines, ect.
http://www.schwankeshortblocks.com/E...e/HPIM0107.JPG
Let me know.
Check out our website, there is a Jeep on there with a 5.3L.
http://www.schwankeshortblocks.com/U...Jeep%20015.jpg
http://www.schwankeshortblocks.com/U...Jeep%20017.jpg
Let me know.
What should I expect to pay for a good used intake?
Remember that a high point on the LQ9 with the standard accessory brackets will be the alternator. (My LQ9 into a Jeep)
Good luck!
Good luck!
Later, I may change oil pans, but I'm going to start with the stock set-up.
I can post more pix if needed.
