Patriot Gold Install Height and #'s on Seat???
Old 01-23-2008, 08:46 AM
Formulized94's Avatar
Default Patriot Gold Install Height and #'s on Seat???
Does anyone know what the install height should be and how many pounds on the seat there should be?
The reason I ask is i have a set from when I was cam only with a 224/228 .588 lift, that have 2000 miles on them. The guy at the machine shoop is telling me that they only have 110#s on the seat and it should be around 140-155??? However, he didnt say at what height that was, I am just curious if maybe he doesnt know the right install height or what?
Old 01-23-2008, 01:31 PM
PREDATOR-Z's Avatar
O.D 1.29
135lbs @ 1.800
385lbs open
coil bind @ 1.08
.650 lift
Indepedently tested PP golds:
seat: 143 lbs @ 1.800
open: 363 @ 1.200
coil bind: 1.060
Clearance: .140
spring rate: 367
Old 01-23-2008, 06:44 PM
thanks.
Anyone know anything about the manley next tek MAN-221436-16???
Old 01-23-2008, 06:56 PM
vettenuts's Avatar
I would figure out why you have 110 on the seat with the Patriots. I would also take the Patriots over the Manleys myself. Did he give you an installed height or is he saying the lost their seat value?
Old 01-23-2008, 10:04 PM
install height was checked at 1.800 with the seat and retainer in place.
Old 01-24-2008, 07:03 AM
vettenuts's Avatar
I would shoot a PM to Gunnar and talk to him about it before deciding what to do, something doesn't sound right and he may be able to provide some insight on things to check prior to going forward. Hopefully if there is another issue this will help avert problems down the road.
Old 01-24-2008, 07:42 AM
1ORANGEWS6's Avatar
Have you looked at the PRC dual springs?
