Cam
Old 07-07-2003, 07:17 PM
OneBad LS1's Avatar
Default Cam
Is anybody running a 581/581 224/228 114 cam.I was thinking of getting this but want any info on it.Its a custom grind.My biggest worry is keeping the car started. Any info would be helpful.This will be put on a m6 car (not car in sig)THANKS
Old 07-07-2003, 07:21 PM
Smoke_Ford's Avatar
Default Re: Cam
I am running the .581/.581 224/224 114 cam. With an A4 car, you are going to need tuning or the car will not be drivable.
Old 07-07-2003, 07:24 PM
OneBad LS1's Avatar
Default Re: Cam
What kinda tuning?I have a diablo will this work?what about the tb will it have to be drilled and if so how much?Sorry for all the ?
Old 07-07-2003, 07:41 PM
Smoke_Ford's Avatar
Default Re: Cam
I am not familiar with diablo. The TB must be drilled. If you have access to any kind of scan tool you can read idle air counts. You keep drilling larger and larger until they are 20-30. I forgot what the biggest you can go is before you have to start a new hole. There is a member by the name of RPM WS6 that can give you what ever info you need. I don't know if he browses this section.
