what size nittos
what size nittos
getting nitto 555 perf. tires not the drag radials though. i have 17x 11's with the 50mm offset out back on the camaro what size will be good with no rubbing i heard nitto run pretty wider than others?
I'm not sure who told you that nittos run wider than most tires, but that is the opposite of the truth. They definitely run narrower. I'm running 315 35 r17's on the rear. They are the 555r's but I can't imagine the regular tires being different in size, just compound.
