Dot 4 fluid in brake MC too?
The clutch master cylinder says "Dot 4 only". If I have the brakes drained, is it OK to use Dot 4 in the brakes too? I know you are not supposed to mix.
That makes sense. I am starting with a new master cylinder and new brake cylinders. I would assume that if the system was empty I could change. I have heard you should never mix. I just wanted to hear this from someone that new what they were talking about. Thanks
Any more comments from anyone???
