Heater is not hot just warm(HELP it's Cold)
Old 01-24-2008, 04:48 PM
5301113's Avatar
Angry Heater is not hot just warm(HELP it's Cold)
Last few days it's been cold here and i have been trying to use my heater but i have noticed that it never gets that hot just warm . I have warmed up the car to normal temps and i have turned off the heater then turned it back on, I think i mit have air in my ac/heater lines because sometimes the heater gets cold then warms up again. Last year i just had the whole AC system replace because the compressor was weak and not working as well.
Has anyone had this problem?
Any help would be nice?
Old 01-24-2008, 05:12 PM
KCFormula's Avatar
If you have a stock Tstat it sounds like your heater core.
Old 01-24-2008, 07:15 PM
TXFORMULA's Avatar
yeah,do you have a stock t-stat or low temp ?
Old 01-24-2008, 07:20 PM
Black02SLPSS's Avatar
If its your stock tstat it could be stuck open in which case needs to be replaced which is what i had to do to get heat back. Now if your very unlucky then it could be your heater core which will be a pain in the *** to replace. So what i would do is try replacing the tstat first and see if that fixes your problem, then go from there. It may not be a bad idea to go back with a stock temp tstat or go with a 180deg, anything cooler than that without a tune may cause your car to not come out of a closed loop run and make your gas mileage go to ****. Just a thought
Old 01-24-2008, 08:37 PM
bowtiepastya's Avatar
if you bring it up to temp and its still not blowing hot then its not you thermostat (and its not overheating)... i would try flushing the heater core before replacing anything... the heater core is easily clogged by build up and rust... why buy a new one if you can just flush the hoses and core.
Old 01-24-2008, 10:25 PM
socal's Avatar
i have 4 f-body's and nun of them get hot just warm but then again they never reach over 180 in the summer and thats here in houston
Old 01-25-2008, 08:44 AM
02 BLK WS6's Avatar
I have a 160* stat and my heat keeps the interior cozy, but the heat has to be cranked in this single digit weather.
Old 01-25-2008, 08:48 AM
crazylane's Avatar
Might wanna check your water pump as well. If it is a high mile water pump, it may not be curculating the fluid like it should be.
Lane
Old 01-25-2008, 09:27 AM
radkon's Avatar
Flush the cooling system then replace the t-stat with a 180, fill it with new coolant and distilled water and you should be fine.
Old 01-25-2008, 11:07 AM
5301113's Avatar
I think stock i have never changed it. I think i will change out the t-stat first and go from there.
PunkerPontiac's Avatar
there is a TSB that may help you. there is some foam that seals the heater core to the box, and when the seal deteriorates/get pushed out of the way it allows air to bypass the heater core. so before you go and spend a bunch of money replacing parts i would see if you can check the seals in your heater box. hope this helps.
Old 01-25-2008, 11:10 AM
5301113's Avatar
I flushed it last year
5301113's Avatar
Lane
How do i check the water pump?
Old 01-25-2008, 11:12 AM
5301113's Avatar
How do i flush the heater core?
How much does is cost to get it flushed?
How much does a new heater core cost?
Old 01-25-2008, 11:15 AM
5301113's Avatar
Ok what is TSB?
