whats your tire pressure?
Old 01-25-2008, 04:25 PM
Adam013085's Avatar
Default whats your tire pressure?
I was just wondering what pressure everyone runs on their tires. I just have the stock rims and tires on my t/a and just wondered what some ppl used as pressure on their stock tires.
Old 01-25-2008, 04:26 PM
boofthese's Avatar
LOL im running about 15lb in back right now LOL i havent filled them back up since i was at the track
Old 01-25-2008, 05:29 PM
Adam013085's Avatar
haha maybe i should rephrase it and say whats your street tire pressure
Old 01-25-2008, 05:31 PM
Benner's Avatar
I usually run at about 36 pounds when it's cold out
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
34-36lbs. Actually, I put in 36 yesterday....
Old 01-25-2008, 06:06 PM
Adam013085's Avatar
cool thanks guys now I got an idea what to run in mine
Old 01-25-2008, 07:48 PM
kenp's Avatar
30 lbs. Anything more and both ride and handling go to crap.
Old 01-25-2008, 08:29 PM
_JB_'s Avatar
30psi here cold.
Old 01-25-2008, 08:45 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
The door decal also tells you how much psi to put in them.
Old 01-25-2008, 10:55 PM
Formula350's Avatar
Unless you run tires other than what the door says to run, in which case that PSI goes out the window.
I say, if other than the sticker tire size, run what the tire SAYS
Old 01-26-2008, 12:26 AM
99'CajunFirehawk157's Avatar
30-32 psi, anymore, not sure I could stand it with the sh1tty roads we have here, they suck. And I have good shocks too, Bilsteins.
Old 01-26-2008, 12:33 AM
xXSilencerXx's Avatar
How so? I'm runnin a 245/40R18. 30 psi is not right? Not callin you out, just curious.
Old 01-26-2008, 04:49 PM
ghardester's Avatar
32 all around on Toyo Proxes 4's.
Old 01-26-2008, 05:41 PM
NC01TA's Avatar
30-32 psi on original stock here as well. More than that = rough ride. Very even wear and no issues.
Old 01-26-2008, 05:51 PM
wickedbluess's Avatar
35 Psi
Old 01-26-2008, 08:15 PM
sleepinghawk's Avatar
There is no tire rating on my doors, I always run just under what the tires say to put in. My stock firehawk tires call for 44 being max. I run about 35 or little over. Tires wear even for me.
Old 01-27-2008, 11:01 AM
Copy & Paste Moderator
VIP1's Avatar
I have 275/40/17 GS-D3 tires @ 30-32PSI (usually 31PSI)
Old 01-27-2008, 01:12 PM
bu01's Avatar
on my bu i ran 35-40 psi, never had a problem, so i am going to do the same on the WS6
Old 01-30-2008, 01:13 PM
Sharpe's Avatar
I want in on the dogpile! 35 psi on both street and strip. No luck getting better traction deflating them.
Quick Reply: whats your tire pressure?
